TwinTurbo.NET: Nissan 300ZX forum - Went back to Town Fair
FrozTTy
on February 09, 2019 at 7:01 AM
Help with Suspension/Steering
posted by FrozTTy
on February 01, 2019 at 10:40 AM
Guy put Z in the air and checked front and rear. Nothing was loose.
Must be my bad speedo causing steering and HICAS issues.
All bushings and boots in the rear looked ok for having ~180k on them.
Thoughts????
FrozTTy
10:40:45 02/01/19
Re: Help with Suspension/Steering
Metacom
14:46:15 02/01/19
Had 4 wheel alignment done when I got
FrozTTy
18:22:09 02/01/19
Re: Had 4 wheel alignment done when I got
Metacom
22:20:26 02/01/19
Your caster or toe are out of spec (n/m)
21:12:19 02/01/19
If his speedo keeps dropping out, wouldn't that also
MixManMash
22:58:24 02/01/19
I believe so
FrozTTy
06:33:16 02/02/19
Yes - likey needs to rebuild the gauge cluster (n/m)
10:42:39 02/02/19
Went back to Town Fair -
FrozTTy
07:01:43 02/09/19
Check the rear HICAS inner tie rod ends
Doug71zt(CAN)
22:23:24 02/09/19
Thanks for your input
FrozTTy
07:30:05 02/10/19
Re: Thanks for your input
Doug71zt(CAN)
22:44:53 02/15/19
Is there some write-up I could follow for this?
FrozTTy
07:30:35 02/17/19
